If you had all of the Funds and Parts availability to build a Mopar engine perfect for how fast you want to run, what parts would you use?
You can copy and paste the below to make replying easier.
Block
Crankshaft
Head Assembly
Connecting Rods
Pistons
Bearings:
Cam
Oil Pump & Pan
Intake and Carbs:
Other
Other Details:
How much HP and TQ would you expect?
Block
Brand:
Iron or Aluminum:
Wet or Dry:
Bore:
Iron or Aluminum:
Wet or Dry:
Bore:
Crankshaft
Brand:
Main Journal size:
Rod Journal size:
Main Journal size:
Rod Journal size:
Head Assembly
Head Brand/Model:
Valves:
Rockers Brand, Model & Ratio:
Pushrods Brand, Thickness, Ends:
Springs Brand, Type, Pressure:
Valves:
Connecting Rods
Brand/Model:
Length:
Rod End Size:
Length:
Rod End Size:
Pistons
Brand:
Flat Top, Di shed or Domed:
Bearings:
Main:
Rod:
Rod:
Cam
Brand:
Lift:
Duration:
Lift:
Duration:
Oil Pump & Pan
Brand/model:
Pick up type:
Oil Pan:
Girdle Y or N:
Windage Tray Y or N:
Pick up type:
Oil Pan:
Girdle Y or N:
Intake and Carbs:
Intake Brand/Model:
Carbs Brand/Model/CFM
Other
Distributor:
Wires:
Plugs:
Crank Trigger Y/N:
Balancer Brand:
Timing Set:
Vacuum Pump:
Headers Details:
Head Gaskets:
Water Pump:
CID:
Oil Brand, Type and Weight:
Race Gas Brand/Octane:
Wires:
Plugs:
Crank Trigger Y/N:
Balancer Brand:
Timing Set:
Vacuum Pump:
Headers Details:
Head Gaskets:
Water Pump:
CID:
Other Details:
